KRM offer a wide range of power harrows from a 2.5m Maxim through to a 7m folding Magnum
KRM Kratos
The KRM Kratos power harrow is available in widths from 3 to 6m and features a 200hp gear box (250hp on folding models). Other features include quick release blade system, SKF taper roller bearings, automatic torque clutch, heavy duty headstock and support frames.
Leaflet Specification Gallery Features
KRM Maxim Special
The Maxim Special comes in a range of sizes from 2.5 to 6m. Changing the gears on this 190hp machine gives rotor speeds of 313rpm or 359rpm at a PTO speed of 1000rpm. Standard equipment includes 21z shaft with friction clutch protection and quick fit blade system.
KRM Magnum Special
The heavy duty KRM Magnum power harrow is available in widths from 3 to 6m and features a 250hp gear box. Other features include quick release blade system, SKF taper roller bearings, automatic torque clutch, heavy duty headstock and support frames.
Gallery
Standard Features
All KRM power harrows benefit from the same standard features. All have 4 rotors (8 blades) per meter giving a finer tilth and easier driving, this configuration also ensures both outer rotors turn inwards reducing ridging between passes. Top quality SKF taper roller bearings are used for rotor support requiring no additional greasing and offering exceptional reliability. Centrally mounted gear box, rear clod bar, and twin position floating lower links are all standard. All our power harrows have heavy duty head stocks making them ideal for use in seed drill combinations.
All KRM Power Harrows feature the same quick fit blade system. Each blade can be quickly and easily changed by removing a single pin. Significantly reducing downtime for increased productivity.
Keith Rennie Machinery Ltd, Registered office: Clay Pit Lane, Bar Lane Industrial Estate, Boroughbridge, North Yorkshire,YO51 9LS
Tel: 01423 324221
Registered in England No 2050946 Vat No GB 431025309, e-mail info@krm-ltd.co.uk
Fax: 01423 324355
